Rather than building a pair of four-way speakers, I would build two three-way pairs with the drivers you have.
I would use an 18 dB/octave Butterworth high pass on the tweeters, and probably 6 dB/octave low pass filters on the mid-ranges and woofers. Whether or not to add a 6 dB/octave high-pass on the midranges as well would depend on experimental results.
Pair A would use T-27, B-110, B-139
Pair B would use T-27, B-140, B-139 + passive radiators.
I would consider splitting pair B into two cabinets/side, a two-way, and a bass box. Pair A would use a sealed alignment.
This way, you not only make use of all your drivers, you also avoid a fair amount of complexity in the crossovers, which should be easier to design, and sound better as well.
