The 4B-NRB I had came with the performance sheets showing the THD per channel. So they did seem to tout that as important metric of health at some point.
Look at the Stereophile 3B-ST measurements:
https://www.stereophile.com/content/bryston-3b-st-power-amplifier-measurements
At 120w into 8 ohms they are down close to .0012% THD. At 2 ohms they are closer to .007%. Bryston doesn't mention in the specs what load the 120W is being driven into. So if its up to .007% distortion at 120w at 8 or 4 ohms, then your amps may be more out of spec than the numbers look like on the surface. Also, Stereophile measured the balanced performance lower than the unbalanced (edit: had those switched) performance. I'm assuming the spec-ed .007% takes that into account too.
