cafe latte
Addicted Member
I bought a Bugle 4 as a back up phono stage as recently my much much more expensive phono stage psu died. Due to my business I need a versatile phono stage to test cartridges so the loss of my phono stage even though it was only for a few days was very inconvenient.
I have a MM and MC on my DNM, but no options to change loading easily or gain which I need.
I did not expect huge things from the bugle, it was bought just as a back up to ensure I am not stuck again, but was I in for a surprise...
Negative points first, the highest gain is 64dB, my main phono stage has over 80dB gain which is great even when I use my transformer passive preamp. 64dB is on the low side for the very lowest gain MC's. Also on the highest gain setting there is a slight hiss which my main phono stage does not do. The hiss is minor and would not get in the way of the music and you will only need the highest gain on quite low output MC especially on a traditional preamp and not a passive one.
The surprise was how good this little phono stage sounds, apart it's mentioned short comings it sounds just as good as my far more expensive preamp and it is way way easier to switch gain and loadings which is something I really need.
It is so good, I am going to set a turntable permanently with it and it won't be a reserve preamp, I expect to use this a lot despite its small short comings as sonically it is very good indeed and it's flexibility will make testing a lot easier.
Chris
Chris
