MadcapLaughs
hello,
Wondering if anyone had any ideas about why my Scott lk 72 integrated amp might be generating sibilance on all my LPs? I am sure that my turntable had been correctly set up as it does not produce ANY sibilance when plugged in to my Sansui receiver and Yamaha integrated amp phono stages. I have tested to see if tube socket connections are solid. I should mention that the amp has been completely recapped (orange caps in the phono stage and all over). Power tubes biased, overhauled completely. I have NOS telefunken long plate 12ax7 in the preamp, I have swapped in RCAs with same results. Am I out of luck here, do I need to just move on to an outboard phono pre? It is such a nice preamp except the sibilance butchers any enjoyable lp with vocals.
