From an earlier post the consensus of AK'er thought that I have a Signet TK3E, and I have not taken it off to confirm, but I am thinking of a Holiday gift for myself. Replacing the stylus. I had purchased the turntable with the Cartridge and have no idea the time on the stylus, so a replacement can only be and improvement (?)
But would my money be better spent looking for a replacement cart?
Searching, I found the likely replacement stylus are the TKN1 TKN6 or TKN22
at adcon.com (http://www.adelcom.net/SignetStylus1.htm) the TKN22 is going for $184
and at lp gear its $99
http://www.lpgear.com/product/TK7E.html
The question is, could I get a better Cartridge for the same money? Is the TKN22 the best replacement stylus? In my previous post someone stated that the TK7E is the bigger better brother of the TK3E and the difference is in the stylus.
Are there other part numbers/replacement styles that my searches have not turned up?
I know this is an old thread but i just bought a TKN22e from http://www.adelcom.net/SignetStylus1.htm to have as a spare for my signet TK7e ill post updates when i get it...
Hey Larry the tk22 was an NOS stylus but I’ve move up the the TK9 cartridge since and I have to say that I really love itL-82 - To once again revive an old thread. Was the stylus you received an original Signet or a reproduction? Which L-82? I have an original ‘75 4 (now 5) speed.
You can use the Audio Technica stylus that fit in a Signet TK7, not sure which ones I’m sure someone will chime in.L-82 - Thanks for the information. I bought a used TK7SU but the stylus is really worn. So I’m looking for a replacement. The L-82 is a nice motor and has some really high quality components (many holdovers from the original LT-1). It doesn’t get the credit it deserves.
I know it's a late reply but there is a grave mistake:I have a TK7E body and use the ATN20SS from Group E. One of my best carts/stylus combos! I was fortunate to purchase the stylus before prices doubled.
The ATN15XE at $90 over at LPGear sports the same tip specs as the TKN22.
The ATN20SS does not fit onto the TK7e!
Nor an ATN14/15
Of course one can "cut it to fit"
If your ATN20SS fits you must have the Signet TK7ea and not the Signet TK7e.
The ATN13/14/15/20 all fit on the later Signet ea Series not not on the early e Series!
Just recently I got a NOS Signet TK7E from USA.Sorry, but I think you're wrog there.
For one thing, I'd expect AT15/20 family needles to fit on Signet TK1E to TK7SU family bodies - whereas the ATN13, ATN14 et cetera (e.g. ATN13d, ATN13E, ATN14E et cetera would most likely be a tiny bit too narrow on the inside at the rear end.
And in my view the round plug of all the older needles is definitely too wide to fit into the rectangular hole of the "wider AT120 family" (my nomenclature) bodies, to which the TK1Ea to TK7LCa bodies also belong.
Greetings from Munich!
Manfred / lini
I posted some here:Are there any cross reference charts for AT cartridges and styli? The shure list is invaluable, seems odd nobody has put together one for AT. It would require far more historical knowledge than I hold but sure seems to be a need.
I was wrong with the Signet ea Series: They have a different design and it is the VM510/520/530, and VM740/750/760 Series which will fit.I know it's a late reply but there is a grave mistake:
Nor an ATN14/15
I have a NOS Audio Technica AT20Sla with orig. Stylus (...)
My tk3ea will take an atn stylus.
