Signet stylus replacement
Hmmm, strange... Shall mean: That the ATN14 wouldn't properly fit onto a Signet TK1E to TK7SU family was just what I expected - but I'm really surprised, that the ATN20 wouln't fit.
If it's not too much work for you, could I ask you for a side-by-side side view pic as well as a side-by-side bottom view pic of your AT20SLa and TK7E bodies, both pics without needle - and also a side-by-side top side (or respectively inside) view pic of your ATN20 and TKN2?
And you are right: The ATN20 does fit, I had to give it (reluctantly) a strong push/pressure and it clicked in (see last photo)
The side of the plastic though doesn't fit as it would be perfect. There is a small (air-)gap
The TK3Ea body should take pretty much any "wider AT120 family" needle - except the Signet MR 5.0 family needles, 'cause the plastic holders of these have a bit too high side walls.
Ha! Indeed this is also spot on. Tried myself a week or two ago and found this same result.
(...) The side of the plastic though doesn't fit as it would be perfect. There is a small (air-)gap
Yup, that was to be expected due to the wider connector block of the AT15/20 bodies. Shouldn't really be a problem, though, as the side walls of the ATN15/20 plastic holders only are thinner at the last third of their length - while the side walls are quite a good bit thicker at the first two thirds, so that the fit at/around the actual generator shell should be pretty snug.
Greetings from Munich!
Manfred / lini
P.S.: Oops, almost forgot - thanks for the pics!
edit: post scriptum added.
Manfred / lini
Your're welcome! It is always good to be able to learn.
I tried again the ATN14 Stylus but here the sidewalls are too narrow. Or from a different perspective the Signet 7E body is too wide.
What are your favourite Audio Technica MM cartridges if I may ask?
Well, in terms of sound-quality there are quite a few more, that I like, but all in all I favour the "wider AT120 family" as that offers a pretty wide choice of both halfinch mount and (to a lesser extent) also T4P/P-mount body variants and a very wide choice of needles in combination with hardly any body/needle compatibility hurdles. That being said, I'm not so fond of AT's recent trend towards higher tracking forces and lower compliances, though.
Manfred / lini
Manfred / lini
It's not just them, seems like it's getting harder and harder to find higher compliance styli these days. Perhaps it's where the market is, not as many ulm arms on new tables. Shure may have been driving the high compliance side too, that influence is gone.
