Silly question? Stacking tuner and amp heat concerns.
i have used rubber stoppers from the hardware store to raise stacked components above an amp vent. looked fine to me and seemed to ventilate well
I'd install two 4" whisper fans behind the unit and wire them in series to reduce the noise generated. You might get by with one but if there is a noise issue two is the simple solution. I hope the area behind the unit is totally open and not partially blocked or totally sealed. Place a cooking thermometer in the back of the cabinet. I f the demo gets over 104 degrees F you are in trouble.
