Spectrum77
Very best luck with this project! Your excitement is tangible. Great hobby, ay?
A valid point. Simi, at this point we're guessing about your PR. I'm just using some numbers that came out of the sim program and are pretty generic.
If you tune to 40Hz you're looking at a single 6" dia x 5 1/8" long port.
If you want to play around with the PR, then by all means do so. But it would probably be easier and safer, especially for the cab, to go ported. Not saying a PR won't work or trying to talk you out of it, just pointing out.
I wouldn't assume they will be angled in until you listen to them. Mine sound better squared to the wall. Another option for the port is the bottom since they are raised off the floor 3.5". If you add legs they will be higher and will raise the CD closer to ear level when seated.They will be in corners of the room angled in..
So if I use the length and diameter you are stating here, then the box will be tuned to 40hz and I won't risk over excursing the driver correct? So at 35hz, how far rolled off db wise will I be?
I know even less than Similost, but am really learning here. How will damping material affect the low frequency in this application?
