Wigwam Jones
Caesar non supra grammati
Speakers are vintage Allied-Knight 3-way speakers, bass reflex design, with Utah drivers. 12 inch woofer, 8 inch mid, 3 inch tweeter. 8 ohm nominal.
The crossover is extraordinarily simple, but I'm having trouble figuring out how it works.
It consists of two capacitors and an L-Pad.
The incoming connections go straight to the woofer, so that's running full-range, I guess.
From the woofer, there is a straight wire to one side of the L-Pad. From the other woofer terminal, there is a wire to the other side of the L-Pad, with a 4 uf 50v cap. The middle terminal on the L-Pad goes to the tweeter. The other side of the tweeter goes to the midrange, which is also connected back to the woofer. The other side of the midrange goes back to the woofer, with an 8 uf 50v cap.
No inductors of any kind are present.
If I just look at this logically, it looks like a typical 1st-order Butterworth network for a 2-way speaker design, but modified for 3-way. The 8 uf cap indicates that the mid is crossed at 2500 hz and it runs full-range from there. The tweeter is crossed at 5000 hz. I think.
I must be missing something. This design makes no sense to me.
Anyone?
Anyone?
