No crossover. And I stand corrected: there's no cap (or coil) on the woofers (8") — I let them roll off on their own, on both the low and high ends.
Cool...
Audioquest Rockefeller solid-core copper cables on the woofers and Nordost Blue Heaven silver-plated copper cables on the mids/tweeters.What are the different "types" of cable? Anything simple, like solid core for bass, stranded for higher freqs?
Like so much in audio, almost any circuit, output class, tube/SS, source, cable, and speaker design ... just about anything can be made to work well, even though manufacturers and audiophiles may disagree.
Some very expensive speakers have one set of inputs, while others have two - serving split crossovers. When bi-wiring, consideration must be given to the two cables so their characteristics don't create discontinuity in driver response. The same for using compatible amps when bi-amping.
Bi-amping generates some questions: is it really the best route or does that depend on each situation? This method invites using a smaller amp for the higher frequencies and more power for the woofers. Even using amps from the same manufacturer, different amps for treble and bass drivers might not mesh properly.
Bi-wiring a bi-amped system is another ball-o-wax to wrestle with. Different hi & lo frequency cables may hinder or compensate for using two different hi & lo amps. This seems like it could be endlessly complicated, involving a lot of testing and comparing.
Is there much agreement about going "bi" or keeping it straight and simple when there's a choice?
Well, in both cases he mentioned using different amps. As one who highly values coherency, I would not prefer you using one amp for the top octaves and a completely different one for the lower octaves as soundstage continuity could suffer - unless the second is used for subwoofer frequencies only.apparently you've never tried vertical bi-amping with two identical amplifiers, one per side.
