marantzfan
Nothing to add yet, just..
Yeah- Yeah- Yeah!!! to this project!. Did you simulate bass response of
the 2226 in that ported enclosure?, what would be your F-3 ?.
Secondly, these blue grills on your Speakerlabs, where's the cloth from?
it's cool looking! (JBL blue?)...
Good luck with your project!:thmbsp:.
GordonW simulated it for me, the box is tuned to about 41Hz and the F3 is 45Hz
Not expecting a lot of low bass from these, but maybe I'll find a 2225 or two and recone to 2235 for a sub.
Dead 2225 frame + aftermarket recone kit = 2235 at half the cost of the 2226, probably...
EDIT: Though, there is one "franken-woofer" I've wanted to build. Use a 2226 frame, the voice coil for a 2241, a 2235 cone and spider, and the 2226 dustcap and gaskets. Wonder how a vented gap version of the 2235 would sound??
All it would take, is someone with some dead 2226s, to find out...
Regards,
Gordon.
Not just yeah, but HELL YEAH, to this project. :thmbsp:
Regards,
Gordon.
Hey Will since you are making your baffle of multiple layers only the outer layer needs to be the proper cutout size for your waveguide. You can actually get the hole size down quite a bit ameliorating some flexing and if taken to an extreme the wavequide can fit into a angled baffle hole with a sound deadening material like dum dum filling in the gap. Kind of a long sentence. Hopefully you get the idea.
Dum dum is 3m strip caulk btw.
Nice, I like the appearance :yes:
Sealed?? If BR, whats the porting plan (location)?
RC
Interesting design. I assume the other cab will be mirrored of this one?
I need to work on the design a little with the port placement. The problem is that they are so large in diameter that they will only fit on the back.
They will be likely in the bottom corners at least 4" (tube diameter) from the bottom and side walls.
That's too complicated for me, plus I already have the ports!
