SL-1200 Platter stuck
eenyok
I can't seem to get the platter off of my mk2. I had another technics DD that I had no problem taking the platter off of, but the sl-1200 refuses to let me remove its platter. Is there some kind of trick to removing a stuck platter?
Yes, if not done properly, it can be hard to come off. Here is what I do, remove the mat, place your thumbs on the spindle, and your middle fingers in the holes in the platter, then while pushing down on the spindle with your thumbs, pull up with your middle fingers. I know it's hard to visualize, I hope it makes sense. Be careful not to damage the magnet under the platter.
CAREFULLY put a piece of soft wood on the spindle and LIGHTLY tap it with a rubber mallet or very small hammer.
The vibrations will loosen it up.
Remove the platter with a quick, upwards "lift" by inserting your fingers in the platter holes and quickly, firmly pulling up.
DON'T hit it hard or you can end up putting strain or flat spots on the spindle.
EDIT-
I see Vincei beat me to the punch. Yes, try his way first. My way is only if it's really bound up.
Thanks guys.
Still can't seem to get it off even with the wood/mallet. Maybe it's the table's way of telling me to take it to a pro to be serviced instead of attempting to do it on my own.
When the platter on my Pioneer was stuck, I used a hair dryer to warm up the platter around the spindle. Then I supported the platter with shims to raise the spindle so it wasn't bottomed out and tapped the spindle as mentioned above. Don't hit metal on metal. Use a wood block on the spindle or a plastic mallet/hammer.
Get a friend to help...
Pick up the whole TT by the two holes in the platter.. hold it an inch off the table or floor..
Have your friend place a block of wood, or like a nylon cutting board over the spindle, then give it a sharp rap with a hammer.. the table should drop right off the platter.
Also as noted.. using an oil would help too, but I wouldn't use WD-40.. it's not a penetrating oil.. I'd use a penetrating oil such as Kroil or P'Blaster
When I got my 1200, my wife tried to hit it with the hammer for me.. I gave up and had her hold it.. It took a pretty sharp blow to break it loose..
