Slow cassette player
I picked up a Technics RS-M22 cassette player from the thrift store in good physical condition. I cleaned the switches and pots on the front panel,also cleaned the heads and roller. The belt looks okay but plays tapes slightly slow. Before I replace the belt should I check something else? Also I'm having trouble locating a replacement belt for it. The only place I found one was on Ebay from Portugal and a 1-2 month shipping time.
It's pretty much always a good idea to pick up some new belts for any tape deck purchases, particularly more vintage units like the RS-M22. If it uses an idler tire in the transport, it wouldn't be a bad idea to change that either (although if the deck works and the transport isn't noisy, it's probably fine for awhile).
The speed should be adjustable with a screwdriver via a potentiometer on one of the boards. Here's a service manual I found.
https://www.hifiengine.com/manual_library/technics/rs-m22.shtml
Speed adjustment should be done after changing belts - ideally with a speed calibration tape, but it's possible to get close enough for casual use doing it by ear (provided you have a good ear for pitch, and have access to a CD/digital version of the recording on the tape to use as a reference).
Feel free to post back here if you run into any issues. Belts are pretty straightforward on many decks, but some others can be a bit trickier.
Vintage electronics (google) in Walsenburg, CO doesn't carry the belt(s)?
