Mr Creosote
I would not worry too much about using 4ohms speakers with this amp, the manual states power and THD ratings for 4 and 2 ohms load. It should be fine with most speakers that fits on a desk or bookshelves
From my manual:
- Minimum RMS Output Power: (8 ohm, 20 Hz to 20KHz, 0.04% THD) .......... 50W + 50W
- Dynamic Power (IHF): (8/6/4/2 ohm) .......... 70/77/89/100 W
It only mentions 8 ohms for RMS. I'm not sure how to interpret IHF. Elsewhere in the manual it says "Use speakers with the specified impedance shown on the rear panel of this unit". On the rear panel it says "A or B 4 ohm min., A+B 8 ohm min." So you are correct. Since it only mentions 8 ohm for RMS I assumed.... Good to know. Thanks for setting me straight. You made me read the manual.
