No, I haven't heard one.
The first problem is that the 211 needs at least 1,000 VDC, which is lethal. I've been hit with a fraction of that and it got my attention, mistakes never repeated.
Some 211 amplifiers go even higher. Twenty years ago John Camille had one running at 1,200 or 1,300 VDC, don't remember which. Impossible to work on without an HV probe, a hot stick (to disconnect the tech from the chassis in the event of shock), and a paramedic with a defibrillator and a hot shot of adrenaline for the heart. I don't even want to touch a knob on that setup. He also had an OTL one which meant even higher current. Enough to kill a handful of platoons, if not an entire division. Ok, one would have to properly wire the division...
At some point I think tube audio moves into a category where therapy, plus a day program with adequate oversight, is required to keep everyone out of trouble.
The second problem is it needs a custom output transformer with a 20k primary. Hard to get the inductance/capacitance right to maintain flat response at low end and high end.
I'm not afraid of high voltage, BTW, I'm just very cautious. I have a pair of KLH Nines which need power supply rebuilds. Those run at 7,000 VDC, so potted in wax, which must be decanted, to avoid arcing. This spring Ian and I were going to have a group rebuild of those for safety, and I was going to borrow a portable defibrillator from a paramedic friend (this is not a joke, such voltage is lethal), but he died last fall and we never had the chance to rebuild.
You mean legendary for its spectacular RF hash generation? Yeah, it is certainly is legendary.
