knifeswitch
I have most of what I need to start messing around with SMD stuff but wondering if you guys have a standard paste you use. Is quikchip good enough?
Appreciate your "voice of experience" here, Thanks! But you got me thinkin' . . .Been doing smt since the 80’s both in a professional and home setting, never needed to use paste to solder small qty of smt right down to a 0.5mm pitch Dfn or Qfn
I use 15mil eutectic no-clean solder and a temp controlled iron with a small tip.
Suggest to only use paste if you are using a stencil and oven otherwise it’s a mess to deal with, meaning controlling volume is an issue even with a dispensing machine.
A hot air machine is useful for removal and some touch up, that and some liquid flux.
For passive removal I use two irons and heat both lands at the same time, clean the excess solder off pads with solder wick
So you are a professional with an impressive background in aerospace at legendary employers NASA and JPL. Way cool~thanks for sharing!I'm retired now, but used to do this stuff for a living. Had a nice hot air station. Dispensed the solder past with a needle and syringe, I liked that better then the power dispenser. Eventually the parts got so small that I had to use such a small needle to dispense such a tiny amount of paste that the little balls of solder in the paste wouldn't flow through the needle. And the supplier had stopped making a paste that had smaller size solder balls in the paste. That was right before I retired. I worked for NASA Jet Propulsion Laboratory. I had a friend that did only flight stuff, space craft type flight stuff. Very strict tight tolerances and specs. Real small stuff, and he never used paste. But he was really good.
