Soldering... I suck at it
Iron clad, not cast iron, tip
Sorry about posting twice, but I cannot figure out how to edit my post and make the edits show up in the (*#)(*@ forum.
I meant "iron clad" tip, not cast iron. And you cannot buy these at Radio Shack anymore. I've only been able to find them as "leftovers" at various Radio Shacks, and I grab them up when I find them. But Weller and others make iron clad tips. If you can get one of those to fit your iron, do it. Otherwise, I'd buy an iron that takes one of these.
And NEVER scrape or sand an iron-clad tip. You'll remove the cladding and ruin it.
qboneus said:
for crimp type connectors, just crimp them.. no solder needed. A good crimp will be airtight and stonger than the wire anyway so no need.
For the best crimp, use a Klein tools crimper. It does not just mash the connector flat, it holds the round shape of the connector and "punches" one side down into the connection.
To crimp thick heavy duty spade lugs that I use I just use a vice. I doubt my Klein crimper could do the trick. Even though this is a tight crimp I still solder them. I don't see how soldering a crimped connection can hurt it, at least on a speaker cable.
Well there are a variety of ways that theroetically it can hurt.
By adding solder to the wire you are making the whole assembly more rigid and that could lead to 'stress fractures' much like people who have fused vertebrae in their spine often suffer after having the fusing process done.
Making a large, rigid assembly creates a 'lever' effect that just simply wasn't there before.
Dissimilar junctions and metallurgy aren't my forte but I think there are also some disputible minute surface interactions caused by adding solder to the mix.
But I'm no expert, I just know what has worked for me and what I was taught.
I' comfortable crimping crimp connections, and soldering all of the ones that need be soldered,..... to me it's not being lazy, I have literally thousands of hours of soldering experience from prototyping, to building specialized mil-spec+ test instruments from component\pcb level.
Soldering a crimp would have made any of these instruments fail inspection and required re-working, now your speaker cables will never see 5g's but why would you treat them any differently? theory is theory IMO.
Tal
Sometimes when I'm soldering switch pins into a circuit board, the solder wants to stick to the tip of the iron, and not the board and base of the pin.
It looks like some kind of magnetic mercury that will not go where you want it.
What causes this?
What causes this?
Not enough heat probabaly. :scratch2:
I've had problems with switches too — the type with posts that are soldered to directly to the board. Flabergasted!
I have that same iron :yes: I had problems with the screw the holds the tip on, if it not realy tight the tip does not heat up. If you have a drill press drill a hole all the way through where the screw goes in and install a small bolt and nut. I never have had a problem since. After the iron heats up i rub some plumbing flux on it (the kind that just sizels away and leaves no crap behind), it seams to help. I use a piece of steel wool to wipe the tip when soldering, wet cloth is probly better.
