would an 8.2 be ok?Yep and Dayton will be more of the same. Get the Clarity CSA or Janzten Superior Z.
Yes, well within the original tolerance, which would have been either 10 or 20%.would an 8.2 be ok?
I have a pair of 36s that im not going to re-cap because its just right. I may try those other caps to tone it down i feel the urge to open it back up.Decades are bright speakers to begin with. Don't really know what would tame the tweeters. Redid a pair of L36's with IC caps if I remember right. Way to bright for me.
thank you!Yes, well within the original tolerance, which would have been either 10 or 20%.
I made the mistake of recapping some NHT's (hoping for a little better sound) with the Dayton's. At some point I'll be replacing them with Clarity.Yep and Dayton will be more of the same. Get the Clarity CSA or Janzten Superior Z.
The original Obbligato caps work well in NHT speakers. I believe those have been replaced with the Silver series.I made the mistake of recapping some NHT's (hoping for a little better sound) with the Dayton's. At some point I'll be replacing them with Clarity.
Those are really expensive so im not sure i can get those.Yep and Dayton will be more of the same. Get the Clarity CSA or Janzten Superior Z.
you don't need fancy capsThose are really expensive so im not sure i can get those.
I just looked, there are no Clarity CSA caps on eBay. There is a limited selection of older out of production caps that might or might not be real Clarity caps. Always best to buy from authorized businesses.I also find the Clarity Caps (630 volt) to be "dark." You can get them reasonably on eBay. They are HUGE.
Dayton caps work fine in a dark speaker- I put them in my Dynaco A-25's and they sound really good, but in a bright speaker they would probably sound like arse...I made the mistake of recapping some NHT's (hoping for a little better sound) with the Dayton's. At some point I'll be replacing them with Clarity.
Experimenting is half the fun of restoring vintage speakers. I've used the Parts Express non-polar electrolytics and have not heard anything offensive. If the originals are electrolytic, I don't think the PE caps will be a down-grade.If you are willing to experiment, why not try some non-polar electrolytic caps and see how they sound. They are not expensive.
Have you used these before?You could also consider the Audyn Q4's.
Audyn Cap Q4 8.2uF 400V MKP Metalized Polypropylene Foil Crossover Capacitor
Audyn Cap Q4 8.2uF 400V MKP Metalized Polypropylene Foil Crossover CapacitorAudyn has supplied European speaker builders with high quality electrical components for use in crossovers since 1973. Their Q4 series of non-polarized capacitors feature MKP metalized polypropylene foil and are tightly...www.parts-express.com
I am referring to the SA series (I did say 630 volt), and there are plenty currently on ebay though maybe not in his desired values. That's what I use in combination with the Audyn Q4s and that's where I got them. The Audyns are brighter. Like I said, the SAs are HUGE. In fact, there are a lot of different ClarityCap "formulations" on ebay.I just looked, there are no Clarity CSA caps on eBay. There is a limited selection of older out of production caps that might or might not be real Clarity caps. Always best to buy from authorized businesses.
