muchachos
I just put the new one on top of the other - did not even try anything else. My 208 is not yet functional, so could not test the improvement, but when i bought it, the platter bearinf used to make metalic rubbing noises. After cleaning, new thrust plate and oiling it is almost silent, but noises can still be heard when putting the ear next to the spindle. Will have to investigate further after i get it spinning.
Another problem i have encountered is the platter is warped, it has a spot that is about 2mm higher then the rest of the platter. I thought about a heat and weight treatment, when i have the time. As a last resort i could visit a machine shop to remove the "excess material" but i am afraid this would unbalance the platter. And to make it look perfewct, both sides have to be straightened - i am a bit reluctant to do that...
edit: the platter and metal chasis apear to be dirty - lots of small dots that do not go away. Is this the famous pitting typical to these tables? If so, then sandblasting would be the only viable cleaning option? What i find a bit strange is that underneath the platter and motor cover, this phenomenon is almost invisible.
Thought so re: the thrust plate. Thanks!
It sounds like yours may have been subject to some heat or humidity in storage over its life - this would account for the platter warping and chassis pitting appearing as small dots or dirtiness. You cannot sandblast or polish it out as it is not emerging on the surface, but from the inside of the casting outwards - so polishing will in most cases just reveal more of it. Painting or refinishing it entirely is really the only way to address it unfortunately. The platter warpage has you in a tough spot as well.
