Zilch said:"Bottom" like mine are set up, or in the horizontal orientation?
It matters with respect to what's appropriate to load in them....
Manitoulin said:Capacitor
Cool.mxlews said:Vertical like yours.
mxlews said:Dimensions are roughly 20W x 24H x 16D.
If you heard these, it'd likely change your mind about that....mxlews said:Hmm..don't think I really want to spend much money on these.
And how would you address the box tuning?speakerlust said:Would you be interested in loading them with
12 inch Peavey Black Widows?
Zilch said:If you heard these, it'd likely change your mind about that....
If it sounds like ****, they are working.......2DualsNotEnough said:To check if the tweeter is working,use a toilet paper roll up against it and to your ear.
Remove a Utah from the cabinet so you can inspect them better. Do the wires not exit the rear of the basket? Nothing about that model on the internet?mxlews said:I'm still wondering if the Utahs are any good, and how I fix the tweeters. The tweeter wires seem to be soldered to the metal ring on the woofer basket and that's where they end. No cap. ???
I linked you to how just about anything might be put in them. If you look on the inside behind the insulation at the front, you'll likely find the screws securing the baffle to the box. If they go together like mine, all you need is a new baffle for whatever driver load you want.mxlews said:I'm also wondering about my options for the future of these speakers.
