swechsler
Frog Whisperer
Hmm, that's an interesting idea, and much easier. Will have to think about that.Expanding foam in the annular space would also be interesting.
I'm curious if this is a solution in search of a problem. From what I've read, a tube sub with proper acoustic insulation inside performs very well and doesn't really need additional damping.I'd really like to see how nested tubes with internal foam behaved as Constrained Layer Damping.
I run my mains full range.
The miniDSP 2x4HD is fantastic for low-pass subwoofer duty , but adds too much of a sonic veil when I high-passed my main speakers through it.
In addition to summing left and right channels, and low-pass crossover, I also have a mild narrow parametric bump around 25 or 30 HZ, and sharp parametric subsonic cut below 10 or 15 Hz.
(For about a decade, I previously used a Harrison Labs line-level passive crossover that does none of this parametric magic)
I'm not using a microphone and room correction, just good speaker placement and gentle tuning by ear.
I really wish the AD and DA conversion was cleaner, because I'd like to delay my main speakers for tighter transients, as well as high-passing them at about 30 Hz or so.
Audio Research LS7 line stage into a Threshold S/200 power amp is Very resolving with both vinyl and CD.
Subwoofer is currently powered by Parasound HCA-1000, and basically performs the same when powered by Rotel RB-980BX.
The combined system can play real music, cleanly, all day at 95+ dB, with peaks well above 100 dB (Radio Shack meter)
Rest assured that it is ... and good luck getting that expandable foam deep into a void of that depth.I'm curious if this is a solution in search of a problem. From what I've read, a tube sub with proper acoustic insulation inside performs very well and doesn't really need additional damping.
Easy...drill hole through tube wall and insert straw...... and good luck getting that expandable foam deep into a void of that depth.
...a sonotube sub would make good use of that unused cat shelf over the home theater systemThat sounds interesting; I'll check them out. I wonder which driver will play lower. Enclosure size, especially height, isn't an issue, so I'd like it to be whatever will give the lowest bass. Thanks!You should check out the Stereo Integrity SQL driver. It has twice the travel of the Tempest , 28mm one way compared to the 14mm of the Audire driver, twice the wattage rating, 1000 versus 500, lower inductance ( tighter bass ). And it is on sale now on preorder for 269.00
All the SI drivers are very high sound quality drivers. Even their 24" monster sub is audiophile quality sound.
The sensitivity is much higher too. 91db versus 88, 3dB is a big difference. The box size is only 2 cu. ft. for a sealed enclosure which would drastically decrease the size of your Sonotube required.
https://stereointegrity.com/product/sql-15/
You should be able to delete the duplicate.Sorry all, I didn't mean to multiple-post!
