Hi gummy,
Please find below Sony's service bulletin how to test the VFETs. For this, remove the grill on the bottom of the amp, unscrew the VFET screws and just pull tem. There are not soldered, but slotted (the oxidation inside the brass slots being one of the typical revamp actions). Duly cleaning the thermal paste (isopropanyl or white spirit) would be recommended, as it has electrically isolating properties, potentially disturbing the measurements.
As EW recommended, mark each VFET original location before pulling, or directly afterwards cleaning one.
Now, depending on the outcome of the measurements, you are either very lucky or very unlucky. If the VFETs are faulty, then yo better sell off the amps in parts, forget about finding new VFETs (I need some parts). If they are ok, then please never switch on again the amp until fully refurbished.
Despite being a delicate VFET amp, the circuit topology is such that the VFETs get easily killed by various problems caused by aging, such as:
- poor ground connections of the main amp board (connector oxidation)
- poor VFET lead connection (slot oxidation)
- failure of the infamous (hated) double-diode in the bias circuit, aka suicide diodes
- failing driver transistors,
- failing (aging) caps
- etc.
Can you perhaps tell more exactly how 'it died on you' ? If both channels died at exactly the same time, then it might be a common fault, such as the speaker protection relay. Do you hear the relay click open when you switch on the amp? Also, the headphones are tapped off the output signals before the relay, so they should still work if the relay doesn't open. If they don't, then I'm very afraid that the VFETs have died on you, unless the power supply has failed for some reason (but that would be really rare).
Then, there have been some very good threads at AK on this amp, search around, notably concerning the double diodes and how to replace them.
And test first the VFETs as below.... Please tell what the measurement results are.
good luck,
ozzy
