Stoffie
Sony afficionado
if i remember correctly, the true apm woofers have 5 divets on the cone . the ones with 4 divets have a traditional voice coil with bracing extending from the center outward on the back of the cone. i'm sure there are exceptions and someone else will know better than i.
i couldnt tell you exact model numbers other than the apm 77 is a true apm, the apm 66 is not
if you aren't familiar...real apm
"fake" apm.
The 'fake' APM you are referring to is actually from an APM-66ES which I'd hardly call 'fake'.
Those are a far cry from the cheaper made triple digit series which had the looks but not much of the high-end tech of the 'real' APM's.
It's simply the last iteration of the APM development as you can read here from the very knowledgeable Romain (from Sound Oddity) which is probably one of the very few people in the world that could be called an actual APM expert.
A little excerpt:
When comparing the woofers magnets, one could think the 66 are down scaled 55 but they aren’t at all. The 66 have in fact a much more evolved driver’s design, with T shape pole pieces, a strontium magnet material, flat wire OFC copper voice coil, a thinner magnetic gap and an aramid spider. For the same measured MMS of about 65 grams, the measured BL of the 66 is 1.5 points higher with a value of 14.5 against 13 for the 55. It doesn’t mean ether that the 55’s woofers are less good, it’s just that the 66’s woofers are more optimized for less weight.
The driving system of the 66’s woofers is the last APM evolution using 8 points driving instead of 4. It allows to get rid of the 9th order resonance mode of the 4 points driving system originally designed for the APM-8. Consequently, the frequency response of this woofer is flat until 4KHz! Which is kind of unbelievable for a diaphragm equivalent in area to a 25cm diameter cone. The result is an incredibly clear and fast bass response, so detailed and powerful.
I will agree though that the 4-magnet design of for instance an APM-77 woofer does speak to the imagination more
