Bulletseever
Hi All, been restoring a Sony PS-X6 and X7. Did full recap and mechanical rebuild with new grease. They run beautifully, mechanically. There is a catch however. The X-7 has a wow2sigma flutter of 0.01, superb. The X6 has a wow2sigma flutter of 0.1, not great. So i want to adjust the hall gain and rpm offset with RV202, 203, 204 and 205. I have a constant 1.5v dc power supply, white lead wire disconnected, according to the service manual. But with the turntable power and the 1.5v DC power supply I can't measure 1.9v AC voltage on the given H1 and H2 measurement point in the manual. I cant read any AC voltage. I can measure DC voltage, but cannot get this to 0V DC, as this messes up the spinning stability. I have an oscilloscope to see the DC voltage wave from the motor.
Anyone has any experience with these adjustments and cares to help? Thank you all! If any advise is needed on the mechanical part of this TT I can give all the help in getting it to move perfectly, slow tonearm drop and precise needle droppoint.
