The Parrot
Recently I picked up a Sony STR-6045 receiver and it's pretty dirty. This is my first time trying to clean up a receiver and I was hoping to get a little advice. I'll update these questions with answers as I go along in case it helps someone down the road.
I have a couple of questions:
1: Remove all of the knobs, which I have done except for the tuner knob that I'm unable to pull right off like the others. It appears to have a flathead screw that may be keeping it on. I have attached a picture and was hoping someone could verify this. There was indeed a flathead screw that needed to be removed in order to take off the tuner pot.
2: Some of the knobs appear to have had some sort of cloth or fabric giving them a tighter fit. When I try putting one of the knobs back on without the tattered cloth it just slips right off. Could anyone tell me what sort of cloth this is? I was able to wedge the cloth back in though I will use tin foil as another user suggested should the cloth wear away.
3. Other than compressed air is there anything I can do to clean it out? I plan to get my hands on some Deoxit down the road. I used compressed air on it but there is still quite a bit of dirt and muck that remain. Any advice on how to take care of this?
4. There are three dead bulbs that are supposed to light up when Stereo, AM, or FM are selected. With my very limited experience is it possible to replace these three bulbs? I've attached pictures of the ones I'm talking about. I see the section of the service manual that talks about the Stereo light, but I'm afraid I don't see where it mentions the AM/FM lights. I have some lights on the way from Dave, though I'm not entirely sure how to install them.
5. The backlight appears to be out on the unit. Will replacing the two burnt fuses on either side of the Tuner Display put the backlight back into operation? The fuses read: Stanley SS 8V0.3A S83. I have two fuse lamps 8v/250ma on the way from Parts Express that should do the trick.
6. How can I tell if the Stereo / Mono switch is working properly? I’m unable to tell just by listening.
7. Why does the stereo light blink off and on and remain off most of the time? This occurs while listening to the radio, playing from a turntable but not while playing through the aux.
Thank you for taking the time to read this.
