Good save! This is Sony's most powerful receiver.
The service manual shows 65V volts for the V7 and 60.5V for the V6, so the secondary voltages are a bit different. That's close enough for me, although the theoretical power is of course a bit more at 65V. I had initially thought the V7 used a center-tapped secondary for the amp section but it's a quirk of the schematic; no center tap.
There is a circuit breaker for the secondary, labeled CB601, on the power supply board.
There is also a primary side soft-start circuit, also on the power supply board. The soft start uses a thermal fuse + 2 resistors that are shorted by a relay once the secondary voltage starts to rise. If the thermal fuse is open (possibly caused by bad softstart relay contacts or a bad amp channel), then the primary never sees anything even though the power switch is on.
Service Manuals for all relevant models are on HifiEngine.
