TrevorBarten
Well-Known Member
I was working on a tc-k333esg (k950) and while disassembling the front panel I accidentally broke both push buttons because I pulled the plastic covers off while they were pressed in. This caused the retaining bracket on the blue plastic pieces to break which means that the buttons cannot be pressed anymore. I was wondering if there is a modern replacement for these switches or if I can just replace the blue plastic piece. Any help would be appreciated.
I did find these on ebay: https://www.ebay.nl/itm/305651634981
But they are six pin while the ones on the deck are 10 pin and 4 (might be 6) pin respectively IIRC. I am not sure if it matters. Just the name of this style of switch would really help.
