Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Ok, so if my cable between the Pyxi and preamp has only one copper shield end connected to RCA ground, which end should it go on? So far I've used a self made cable with shield connected at both ends, and another with the shield connected only on the Pyxi end, could not detect any differences between these. The 3rd party cable I had been using ( a fancy Morrow) has been put back in the cable bin.
Doesn't the Pyxi have its own independent ground line between itself and the turntable? I would think that you shouldn't add more ground lines to either end. From the cable's weave or anywhere else. This may cause a loop.
To be clear I am talking about the cable from the Pyxi output to my preamp input. The cable from my tonearm is a continuous run from cartridge tags to RCA's and is quite conventional (and not something that will be changed). Or are you talking about floating the shield on both ends of the Pyxi - preamp cable?
Pyxi still sounding good, just listened to my 45 rpm copy of Fleetwood Mac "Rumours" and it sounded fantastic. I'm not touching anything regarding Pyxi placement or cabling unless I get a reason to, I'm not going to try and fix something that's not broken at this point
Good to hear. I think its a great time for vinyl people. There are a bunch of great choices between the Pyxi, the various Darlington, and the Dynavector phono stages.
Me too, a lot of folks helped me through my insanity this week chasing noise, much appreciated. Now it's time to listen (when I get back next weekend from our 30th anniversary trip to Prague, flight leaves in about 8 hours, guess I should start packing and stop listening to records)
Back from vacation, listened to a couple records yesterday and more today on the Pyxi, still going strong. Based on Mr. Boochie's advice a few posts back I built another cable set today to use from the Pyxi to the preamp - Mogami 2549 mic cable (2 conductor) with some nice KLE Copper Harmony plugs - shield floated on both ends. Still no unwanted noise, happily playing music...
Everything still going strong with the Pyxi. Had a surgical procedure yesterday to remove a 16mm kidney stone, today is a R&R day so I expect some records to be spinning today through the Pyxi. Got everything situated now in final locations with good cable lengths/paths. No noise whatsoever.
Time for an update - have been swapping phono stages in/out over the past month as well as my 2 cartridges and doing quite a bit of listening.
With both of my cartridges (AT OC9XML, Ortofon Cadenza Blue) the SOTA and my Rothwell SUT/MM stage are very close, but the Rothwell stage wins. Not sure if it is the influence of the SUT, but the Rothwell is just a bit better than the Pyxi to my ears.
Edited to remove reference to poor performance with the Rothwell/Ortofon.
Rothwell combo back in play for the time being. Unfortunately, my mystery noise has reappeared on the Pyxi (even with the SUT connected to it) over the past day or so, and when I reconnected the Rothwell SUT/MM with the Cadenza this morning things sounded a lot better than two days ago. Not sure if perhaps one of the original connections between SUT/MM/Pre was not solid, or if it was a specific recording on Wednesday that sounded bad. But all is well now in my phono set up.
Not exactly on its own, there have been cartridge and phono stage changes over the past several days.
Edit to add - folks reading this should not take my comments as disparaging the Pyxi. It is a fine phono stage and the noise I am hearing (and writing about) originates elsewhere in my system/environment and is being transmitted through the Pyxi. I've had similar issues with other phonostages. As I said, the Pyxi is great, but it's also up against another fine phono stage in my Rothwell combo, which is roughly 3x the cost...
Have you considered getting something like an isolation transformer to clean up the power to some of the gear? It’s pretty odd that you are still getting noise even with an SUT plugged in as well.
I have two of these Panamax 5510 ACRegenerators that is basically a power conditioner, but for four power outputs it has its own isolation transformer (nothing too high power should be plugged in to those, no amp or anything like that).
The quality of electrical power is often the limiting factor for high performance audio and video systems. Many manufacturers have attempted to address this limitation---caused in large part by electromagnetic interference (EMI) and radio frequency interference (RFI)---by designing and marketing...
www.soundandvision.com
I’m wondering if something like this might help you since your problem doesn’t seem to be confined to a specific piece of gear. I think there’s also other stuff on the market to this that is similar.
I really don't know, I'm already using a Furman power conditioner. At this point I'm grateful that I can use the Rothwell SUT and MM stage with zero issues (not sure what happened there the other day but it is resolved, I blame user error ). For the foreseeable future that will be my phono stage of choice. With that in the system there's simply no noise issue to worry about or throw more money at.
