L-82
I am not sure if this is where i should post this?
I've been listening to my system now for about 2 years and during that time it involved to what I think is a very good set up.
About a week ago i got a test record, the "Shure audio Obstacle Trackability" to finetune my turntable and system.
http://www.ebay.ca/itm/121604502732?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I have a few questions because it doesn't sound the way I remember it used to before the record - things seem to be off. Voices are not as sharp,almost garglie, the sound stage is not as wide and last night, while listening to Barbra Streisand when she hits her high notes she was kicking the but of my system's butt, it fell apart at the seems.
Here are some of the changes
First I adjusted the cart to the head shell, the stylus is set 15.6mm from the center of the tt spindle is that correct? I am asking because the the fron cart suprpasses the head shell by about 1.5mm. I have the arm set just a bit higher at the rear pivot point instead of level with the platter.
Second: Using the test record (tracking weight at 1.4gr) I balanced the outputs (Balance and Phasing stage)of the amp by adding gain until the needle hit the zero db on the meters and balanced the speakers levels at the level adjustments on the top of my preamp C-28. Tone levels are flat with loud off.
I didn't try the to switch back to the shure 97XE with a SAS to see if it would better and if the Signet was the problem because as the record went through the testing phase of the stylus ability to track during the Bells, cymbals, violins i thought that it sounded very strong up to level 5 where Shures says that most carts fail. The only time my system had a problem was at level five with the drums it rattles too much.
Is 14 Grams too light for my cart? could it be that i have too much gain and the amp?
ill try to get more information latter i'm going to retest everything
