Soundcraftsmen reset delay
I'm hoping you bought that electrical formulas book.. lol I'm thinking of another question. I might start another thread.
Here's a warmup for then next question. What are the 4 main resistors that determine the gain of the amplifier? And if you get that, what is the input voltage required to produce maximum output voltage at rated power?
Shirt is on the way.
I would have given you a bonus if you explained, that technically 3.3 seconds is only a rough estimate since the amp is triggered on before the C28 .22uF cap is fully charged...
The cap here is actually charged at a current of .000000763A determined by the 15M ohm R73((12V-.55V)/15,000,000). For the next stage to trigger, pin 2 needs to match the .0001145A at input pin 3. So that amperage plus the feedback through R76 1M ohm has to go through R75 75k ohm.
.00011505A X 75000 = 8.62875V. Plus the .55V at the input means pin 5 triggers the amp on at 9.18V. The cap has .55V on the other side of it at pin 6, so it still only gets charged with 8.62875V.
8.62875V X .00000022F = .000001898C
.000001898C / .000000763A = 2.488s
2.488, or about 2 1/2 seconds is the calculated time from turn on until the triac is triggered or during protection reset.
