Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Thank you for your suggestion. I am actually using a product called ThermoPad to electrically insulate the output transistors from the heat sink. They are made of silicone and fiberglass and appear to be working well.
Sorry, I should have posted here that I solved this problem. When I replaced Qm19,20,21, and 22, I swapped the NPN transistors with the PNP transistors. This caused all sorts of voltage reading craziness, although not any permanent damage. Swapping them back to their correct positions solve all of my problems. The amp is now running great!
