Ok I got -34.07V on F803 and 33.76 on F804. Opposite signs of your numbers...Fasten your black test probe securely to the metal chassis. And probe the fuses with your red test probe.
F803 should have +40 volts at both ends of the fuse.
F804 should have -40 volts at both ends of the fuse.
Let me know if these are clear enough.Post a clear photo of the power supply area of the circuit board.
Typo in the shitty HFE service manual scan.Ok I got -34.07V on F803 and 33.76 on F804. Opposite signs of your numbers...
Still getting this ?No sound through the headphones, just static.
Yeah still getting it. Using a Raspberry Pi with a HiFi Berry DAC plugged into AUX input. Before that I used the audio jack output of my laptop to make sure, with same results.What are you using as a source ?
Check that the two wires going to the LED are still intact.s I mentioned, the “on” LED doesn’t turn on anymore
Is the Tape monitor switch off ?
7.27VWhat voltage are you seeing at the emitter of Q802 ? LED source voltage.
