Speaker Cabinet Construction
Well, I guess I need to start thinking about higher frequencys now :scratch2:
Let me start by saying that 95% of my listening is all strings (bluegrass). No drums, keyboards, or winds. Lots of "high lonesome" male voice, and tons of female voice. I think the big bass fiddle is covered, but what about the mandolins and banjos? I might also add that my high frequency hearing is probably not too good due to years of high pitched centrifugal chiller exposure. :tears: Seems like I like lots of midrange (Heresys have been my choice to date with their large "squaker" horns. I would imagine that I will get some mid from the direct radiator woofer. Other than that I'm fairly clueless. BTW I like "BIG" stuff, but don't want something real "honky" like a huge PA horn. Suggestions appreciated, Jay :D
As per below. This crossover is for the Pi Speakers 4pi Theatre series that uses the similar Eminence Delta-15 and Eminence PSD2002 horn driver and H290 horn.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=290-442
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=290-554
For use with the Gamma-15 woofer:
R1 = 25 ohms, 40w
R2 = 16 ohms, 40w
C1 = .47 uf, 200v
R3 = 8 ohms, 40w
C5 = 47 uf, 200v
A 40w resistor can be made by wiring four 10w resistors of the same value in series-parallel. But since you are using this speaker system with a very low power tube amp, you can just use single 10w resistors.
jaymanaa said:
I'm getting ready to start my first home-built speaker cabinet project. What would be the best material to use? I figure I can either use plywood or MDF. The good thing I see about plywood is, it is allready veneered, but is it stiff enough for bass cabinets. :scratch2: I could really use some tips from people who have built enclosures before. I'm sure there are lots of do's and don'ts, and I would certainly rather learn by listening rather than my usual school of hard knocks and heartaches. Things such as using screws in MDF, types of glue, etc. All advice and tricks-o-the trade are appreciated, Jay
I did research in 1970's as to best material for speaker cabinets in theroy. The material was cement (don't laugh). It does not vibrate HOWEVER it is not practical to use. Cement cabinets are heavy, look ugly and difficult to work with. My professor said ....yup for sure. The next best material is particle board (veneer is optional) because it has no grain to cause vibrations. When you use this material all holes must be predrilled.....you will find out why. The thicker the better..I use two boards sandwiched with contact cement and many screws...one every 6 inches. My system is 1 and 3/8 inch thick. I wish I used just a one inch thick board due to weight. My cabinets are 37 x 18 x 25 inchs.
Here's the important part of any huge speaker job. A really sweet wife. :thmbsp: She has a masters degree in Theatre and said that these would be just about right for a 5000 seat vinue. She also raised a good point when she asked if they would sound right at low volume. I went out on a limb and answered, "of course they will, I know what I'm doing." I guess we'll find out soon enough. :smoke:
Edit- Sorry, I forgot to rotate all the pics in this and the previous post. I hate it when I have to cock my head like that. And BTW the Missus is trying to make a face there, she's actually quite cute. :D
(Insert sound of snickering here)
Really, Jman, this looks great!
That last picture, just above, she seems to be saying, "You've GOT to be kidding me!"
Seriously, she's a keeper if she let you do this... hah!
Those woofers look familiar... let me guess... Eminence Gamma 15's?
You guessed it :thmbsp: Hey Paul, While your here, where can I get the poly-fill for dampening? Would a home-store have any?
jay, your wife looks every bit as satisfied as i thought she'd be. does she understand these speakers are primarily for her?
I keep reminding her that music is an art form, and the only other way I can express myself is by picking on my Banjo. :D That seems to help quite a bit. I will give all the younger AKers a tip for handling their women. Be fair, but most of all be firm! :smoke:
Those are looking way cool Jay! Some big ole horn mid/tweets uptop and yu got somethin there!
Well, here's the pair, ready for sealing, sanding, lamenating, and damping. The diliverance looking pic is what mamma's trying to avoid by allowing these dudes. :thmbsp: Now I have to take a frisbee break says Max :yes:
Edit- Denote "small by comparison" JBL Dorian in back ground. Gotta have work tunes :music:
Yeh, Paul's got me lined out on the comp. drivers, but I'm still looking for some Altec 511's or hopfully 811 horns. I'm going for a somewhat retro look. Planning on using some sort of retro grill cloth in frames on front. :scratch2:
Man, looks GREAT! Some 811's or 511's on top would be very cool!
You can get poly fiberfill batting from fabric stores or WallyWorld's fabric dept.
I have to wait for the monsoon season to stop here so I can start cutting wood myself!
What you are doing is not really much different from these two scoops. One is inverted, but both have the 511 horns on top.
Well, I've never tried anything for the first time without at least a couple of clip leads attached to it. I couldn't resist hooking one up to the old Fisher 200 I was usuing for work tunes. This brings up the first "Important Safety Tip" of the thread.
Do not stick your entire head into the mouth of the horn and wait for "the big bass hit" part of the song intro.
These things go way down. I don't think I'll ever want more than a few good watts in my 20x25 living room. :D
Hahahahahahahahahahaha..... hahahahahahahahahaha!
Are your ears still ringing?
I SAID, ARE YOUR EARS STILL RINGING?
Uh, I take it the woofers work.
H*ly Cr*p! If only you didn't live so far away. I'd sure like to listen to those. :)
jaymanaa said:
Do not stick your entire head into the mouth of the horn...
I'm glad to hear I'm not the only one :nutz:
I'll probably lug them to the Fest. Are you coming? You should see the bump on my head from backing out at a high rate of speed.
Attached Files CrsovrGma15PSD2002
Hey Paul, The values table at the bottom of this schematic is confusing to me. :scratch2: Which set of values do I want to use? I'm going to see what I can scrounge up here, Jay
jaymanaa said:
Are you coming?
Sorry, no. I've just put my kids into a new school and it's been draining my time and my, gulp, bank account :sigh:
It's a shame. It's been many years since I visited the US and I feel long overdue for a return. :yes:
