A theory on the question of size/gauge of the strand. I have read before that the different frequencies of the music like to travel at different depths in the wire, the 20 Hz signal will travel closer to the center and a 20K Hz will ride the outer edge. This effect is suppose to cause timeing and phase errors.
While I have done nothing to explore this concept, it would stand to reason that a larger wire would not work as well as a smaller wire, due to the fact that with this theory a small wire would allow for the entire signal to remain in the same plane as it passes through and the larger wire would not.
As stated before, the above is just something I read and have not really explored. On the surface, it can make some sense. How the theory would play out in the real world, would there be a noticable difference, is it even a correct theory that the different parts of the music would seperate and go through speaker wire in a different area are all part of that exploration process. The best advice so far is to try it and if you are satisfied. Great!
Can skin effect come into this discussion? I am no engineer, just curious.
It's a real enough phenomena, but the net effect of it at audio frequencies is nil.
A lot of cable designers would disagree with you about this.
For the same total cable CSA, resistance will be the same whether 1 strand or 50. The stranding is for flecibility and to reduce work hardening and breakages in use.More strands=greater resistance (very slight) but more flexibility.
Resistance = Rho*L/A
Rho = resistivity of conductor
L = length
A = CSA
My presumption with solid would be they would be factoring some degree of work hardening and increased resistance due to having to bend large solid core. The AS/NZS3000 makes no distinction as 1.5mm2 is the largest solid core legally allowed here. Do not assume that in setting a standard that the results will apply to other areas as the assumptions of use, in this case localised hot spots due to increased resistance at a given point will increase potential for failure of a cable when it is carrying very high continuous currents, not likely to happen as a speaker cable (at least nowhere near the rating of the cable).Not according to the NEC which calculates the resistance per the National Bureau of Standards Handbook. Rho is different. As an example:
#8 solid (16510 circular mils)= .764 ohms/1000'
#8 stranded (16510 circular mils)= .778 ohms/1000'
As previously stated it's a VERY slight difference.
Besides, who uses 8ga solid core for speaker cable? Not exactly flexible and here is finally an application where skin effect might have a more substantial (but still small) contribution.
Rho is a property of a given conductor and doesn't vary. So as the example you gave (and extrapolating to the other gauges) for the same CSA, it will have the same R, all else being equal. An electrical rule book has other considerations when fixing numbers and guidelines which have less to do with the physics and more to do with the pragmatic realities of installation and extended use in a variety of environments. AS/NZS 3000 and 3008 are full of the same. Give me a physics explanation and I might agree, but not with what's presented so far. I see no reason at all for the difference.It was not my intent to "single out" #8 wire, it was merely an example. It holds true for 10,12,14,16 and 18 as well. 7 strand has higher resistance than solid in all cases. Not enough to matter for speaker wire to be sure, but higher resistance nonetheless.
My SWAG is the oxidation between the strands.
Your WAG may be correct, I dunno. However rho is a property of the conductive material, not the geometry.Rho should be relatively constant for a given cunductor. Rho is different for stranded versus solid conductors.
