The best advice is not to get too caught up in the spec wars. It's usually best to take some of these numbers with a grain of salt. They will get fudged a dB or two in the process of putting a spec sheet together.
That said, as mentioned, the number you are talking about is "sensitivity" not "efficiency". As has been mentioned, "efficiency" is the measure of how well the speaker converts electrical power to acoustical power. Sensitivity is defined officially as the output of a speaker at 1 meter, fed a 1kHz signal, with 1 watt (2.83 v) of input signal. It doesn't take a rocket scientist to figure out that if you bump up the output of the speaker at 1kHz, you will score higher on the sensitivity scale, when all you have done is made the speaker more inaccurate to do so.
Once you have that in mind, it takes double the power to get a 3dB increase in output. So a speaker that is honestly 3dB more sensitive over the broad scale, would take half the power to drive. One that is 3dB less sensitive would take double the power.
Now, we can put this into practice with our theoretical wideband sensitive speakers. If our speaker has a wide spectrum sensitivity that is say 90dB. With one watt of input at 1 meter, it would put out 90dB of sound. 8 hours of sustained 90dB sound will damage your hearing. Background music is played at 60dB. 70dB is normal conversational levels and would be twice as loud as 60dB. 80dB would be your garbage disposal in action or a small plane flyover at low altitude.
So, here is the deal. Some speakers take more power to run than others. Unless you like to play really loud, have a very large room, or a very tiny amplifier, sensitivity ratings can largely be ignored, especially with speakers from the major manufacturers. When you go upscale, you will have some issues, but less of sensitivity, and more of being a demanding load. Dynaudios come to mind. Unless you have an amplifier with some backbone, they just don't sound right. Others will have very reactive loads and demand much from an amplifier on the current delivery aspect. Infinity Kappa 9s come to mind.
When you are looking at speakers like a BP8, you are thinking about this way too much. Buy speakers for sound, not specs.
