Oh wow I used to get Speakerlab's catalogs all the time back in the early 80s! Very interesting stuff in there. But one speaker kit I remember in particular used some kind of special active woofer + "semi"-passive radiator system, I think 10" and 12" respectively. Does anyone know how that worked exactly?
They called the large kinda driver on the bottom an Active Hybrid Radiator.
Apparently it was a regular driver that had crossover only for the lowest range where it would work in conjunction with the 10" woofer to extend the range where the 10" would begin to roll off. It was a sort of built in subwoofer with passive components.
Speakerlab 15 was a 2-way, leaf tweeter plus 8" woofer with a 10" passive radiator.
Speakerlab 17 was a 3-way, leaf tweeter, 6.5" midrange, 8" woofer, 10" passive radiator. (same as Speakerlab 15, but with the midrange added)
S300 2-way 3" cone tweeter, 8" woofer, 10" passive radiator.
S500 3-way 10mm dome tweeter, 4" midrange, 10" poly cone woofer, 12" passive radiator.
(This was the model the Graebner more or less copied for me, but less the passive radiator, and with their doped paper cone 10" instead of the poly cone)
Delta I Hybrid Type Five 4-5-way Samarian Cobalt Leaf tweeter, 1.5" large dome upper mid, 6.5" lower mid, 10" woofer, and 12" AHR (Active Hybrid Radiator)
(About the Type Five)
"The 10" upper driver operates in tandem with a specialized 12" device called an Active Hybrid Radiator tm (AHR). The AHR employs a unique high impedance voice coil which draws only a specific proportion of the current supplied to the upper driver. This allows the massive 12" diaphragm to remain in phase with the 10" woofer as if the system was a sealed box. This provides the advantages of gradual roll-off slope, better transient response, tightly controlled cone motion and higher power handling below the system cut-off frequency. The AHR device also furninshes the advantages inherent in a passive radiator system of lower tuning frequency, reduced cone excursion and greater system design flexivility."
Crossover freq was 350 hz, 1500 hz, and 8000 hz.
Delta I Hybrid Type Four 3-4-way Leaf tweeter, 4" mid, 8" woofer, 10" AHR
I would guess that the "AHR's" were really just 16 ohm woofers. They are not listed in the driver spec chart.
And thanks for the great Speakerlab "family photos", Speakerlabfan!
