I have become aware that speaker relays may be a hidden cause for concern in our cherished vintage pieces. I was always slightly puzzled when various AK restoration experts would announce that they had changed the speaker relays. I always believed that they had inspected the relays and decided to change the relays based on visual observation of pitted contacts. I was thinking, "how can they get pitted contacts when the contacts should be closed when the amplifier is playing, and open at any other time when significant currents might be able to flow". The speaker relays shouldn't be subject to drawing an arc when opening, (causing contact damage), except on the rare occasions when there is a fault, but it seems there is another failure mode.
So with the very recent BA-F1 restore, I removed one of the relays and had a close look, no pitted contacts but I noticed an unusually wide actuation distance compared to a new relay, (& no NC = normally closed) contacts - not that unusual. So I decided to energise this relay and measure the contact resistance - WOW - you could have blown me over with a feather, three out of four contacts showed resistances in the KΩ region! So then I got a brand new, although it had been in a parts drawer for a few months, MY4-02-DC24 relay (i.e. 4 sets of change over contacts), and tried that. Surprise! one contact pair showed a high reading varying a lot but less than 100Ω - cover off, one squirt of deoxit and fine, all four contacts then showed less than 0.1 Ω.
So I went back to the old BA-F1 relay, cover off, squirt of DeOxit - no change, tried actuating the relay multiple times (for 'wiping' action), and still the same. There must be a very thin film of oxidisation on the contacts which the tiny voltage/current from a digital multimeter on Ω range can't break though. The BA-F1 got a pair of replacement relays, checked for contact resistance, the new ones sound much less 'clunky'
- Oh and another thing, the coil resistances were 50Ω different on the old relays, (another reason to change), but exactly the same on the new ones.
Lesson learned, while previously not having been on my 'hit list' of items important to change, although I always visually checked the contacts, speaker relays are going to be included from now on.
