RunOutGroove
Addicted Member
I posted not too long ago about ending up with one more set of speakers than I can actually use. I bought these ADS L570/2 speakers that ended up being too large for the remote position that I got them for so I've temporarily replaced the Jamo C103 speakers that were in my living room with these things. I like both of them, though they do sound quite different and I just had the crazy idea of hooking both of them up. I don't think I'd ever want to run them together, but I could imagine switching back and fourth between them depending on what mood I'm in or what type of music I'm listening to. The problem with this idea though is that with the way that my room is oriented and set up is that the only space that I'd have to put two sets of speakers up would be to stack them. The Jamos are smaller so they would have to go on top and then they will be high enough so that the tweeters would be head level, rather than the hight that conventional wisdom would dictate - at ear level where I'm sitting down in the spot where I typically listen. Because of the design of the Jamos, with them being wider at the bottom, I can't really place them upside down so that the tweeters are lower...
I know that I could hook these things up and experiment but with the way that I have my gear set up switching things out is kind of a PIA so I'm wondering if it would even be worth the bother? Would having the tweeters on one set of speakers at 1.5-2' higher than ear level be a really bad thing for the balance of frequencies, the imaging, etc? Some of the seating I have too is pretty close to the speakers and this would mean that the path of the tweeters in the higher up Jamo speakers would be kind of going over my head. One thing to consider is that that these speakers seem to do the off axis thing pretty well as I can hear the stereo separation pretty well even if I'm far off to one side of the pair. I kind of feel that it might be a bit offensive aesthetically though so I'm not even 100% enthusiastic about going this route, which means that I really won't be at all bothered by any responses which say "this is a stupid idea."
