RunOutGroove
Addicted Member
I just bought a pair of Quad 12L speakers, which incidentally I'm quite happy with and as part of the deal I got a pair of Audio Quest speaker wires. They're the bi-wire type with banana plugs on both ends. I'm thinking about using these with another set of speakers that I have, a set of Jamo c103s, which like the Quads also have bi-wire type connections.
First of all, I don't really understand the theory of these bi-wire connections. Sure, if you're using separate amps for the bass/treble terminals, I can imagine that there could be a real improvement in sound over one amp driving everything. I don't understand though how one set of wires that split and go to those same bass/treble terminals would have any real effect over just a single cable to one of those connections that are bridged together. What's the theory on this?
Secondly, the amplifier that I'll be using with all of this is a Marantz 2270 receiver and of course the speaker outs can't accommodate the banana plugs of these wires. Is there then some kind of adapter that would go on the end of these speaker wires which would convert it to something that would fit the tiny connections in the back on my Marantz?
Also, assuming that there is a good way to adapt these wires to my amp, I wonder if there's a good way to extend them just a bit, like is there an adapter than comes with a year or so of wire between the ends of it? my issue is that one of my speakers is a little bit too far from the amp for the length of these Audio Quest cables that I have...
Lastly, I wonder with the amp that I've got if it even makes sense to hook this all up? Am I only likely to get the benefit of these expensive wires if I have a much higher end, higher resolving amp? If that's the case then I'll just sell those things and raise a bit of money towards the cost of those Quad speakers that they came with.
