Speaker wire
You are well on your way, nothing wrong with Rean connects, they are not my faves but..
Currently listening to 2534, and Switchcraft 3502, if I remember ..
It was a bit of a pain to work with, but keeping phono IC’s minimal length, they work well..
Listening to Doors clean vintage pressing, carries the weight.
Yes, I feel synergy matters most, and use IC’s and cabling as…
I am certain, My opinions will garner…
I wanted to like Canare, unfortunately they never impressed me.
Moving forward —- we go.
“When the music’s over —- Turn out the lights.”
Best to you…
What do you do with the third conductor in the 2534?
I think you are referring to the shield.
The end going to your source, ie turntable, cd player etc is soldered to the barrel end of the rca, while the end going to your pre, or amp input is floated, ie: left unconnected.
I was taught this method long ago, and don’t remember the source, I think it is a Japanese thing.
If I get a bit of time later I will pull one of mine and get a pic of it for you. I also really like Cardas eutectic solder, it flows very nicely, and leaves a shiny joint, I guess I’m just used to using it, and don’t forget the flux, I use Cardas as well.
Happy Listening, yard work calls for me….
I use plain old 12g speaker wire from Parts Express. Nothing fancy and crimp fork connectors which work well with my Crown amps and commercial inputs to the speakers. I could get away with a smaller gauge but there are times I have some pretty large systems hooked up and better safe then sorry. I tinker a lot so banana plugs are out because they can become loose gradually and start messing with your sound quality. I fail to see the benefit of expensive wires. At times I have had listeners over who tell me about their great wires. I ask them to bring them next time they come over but somehow they never do. I figure I know why.
Seems pretty reasonable. I just want it to be really soft and pliable. That's really what my post was asking if people had any opinions about working with or using any specific cable. All of the cables being discussed are under $5/ft which is basically in the good, reliable speaker wire category.
Mogami 2549 is on the left and 2552 on the right with Neutrik/Rean gold terminations. This is how they naturally lay to demonstrate the flex in both. I couldn't find any 2534 to compare.
Redco is a good source:thumbsup:
I made a couple sets of wires for my main and office systems using Canare S411 and spade connectors but I was having trouble with the screws in the spades coming loose (every time you move the wires around they work themselves loose) so I just bought a set of Worlds Best Cables (WBC) made with Canare S411 and soldered on gold plated spades. These wires feel stiffer on the ends than my homemade ones. If you want your wires to be limp and lay where you want get the Mogami (I use Mogami wire in my XLR interconnects)
WBC cable link:
First pic is my home made wires, second pic is the WBC:
There is A Swedish speaker wire called Supra that comes in a few different versions and has a pretty high wire count, from memory it is super flexible, and have heard it is a way good wire.
As far as purchasing, you would have to search, it was rather difficult to source, but I think at one time there was an ebay seller that had it.
I always wanted to try it, but…
Don’t know but tariffs may kill buying from Sweden.
Lots of choices you are getting, best of luck on your journey.
I also recommend Supra Cables. I have owned cables from many of the manufacturers mentioned in this thread and Supra has become my go to brand. I talk a little about their cables in speaker build thread I posted here in the DIY section of the forum a few months ago. There are some good sellers located in the US - Madisound and Sjofn HiFi (zendada) on eBay; I have purchased from Sjofn HiFi with great results.
So I finally got an hour or two to build my cables and stupidly, didn't measure the binding posts on my speakers before soldering. They can accommodate 14-12 awg, and the ends are pretty close to 10 awg. There are the obvious ways to deal with this (solder on bananas probably make the most sense), or cutting the solder joint to fit.
Anyone got some clever ideas to save me some time (and tracking down bananas)?
I'm tempted to try those neutrik jobs (NYS508) with both bananas set in plastic, they seem to use a set screw, so they should be fine with the tinned ends. Only issue is they won't go over the cable jacket, but I think that's fine, they'll hold the twisted wires just fine.
I've got a bucket (it's a small bucket) of rean RCAs from some stuff I was experimenting with on my PA, so I'll use those. I think they're perfectly fine.
I think the redco unbalanced is 2497. Ever tried that? I could be swayed to something else if there's a reason (or it's cheaper).
2549 and 2534 are balanced. 2524 looks like a similar unbalanced cable. I'm pretty I used either 2549 or 2534 all over my PA.
I'm not fancy.
After poking round some more, 2497 seems like overkill for interconnects. Super low capacitance though. Maybe I'll get a tiny bit for turntable interconnects.
Mogami 2964 works well for unbalanced and I like Belden 1505F too.
I use these whenever I can. Put some shrink tubing on the wire first. Crimp, then solder. Slide the shrink tubing over the crimped/soldered part and shrink down to insulate.
Here's what my DIY, CAT5 cables look like. Electrically, they're 12g. Physically, more like 10g.
It's not particularly clever but I'd probably just trim away enough to make it fit.
Alternately, you could solder/splice on a piece of 14 or 12ga solid copper.
I'm worried I'd have to take off way too much. I'm going to try to neutrik plugs. I'll report back.
Heck, the trimmed down gauge might even be better in terms of conductivity than putting bananas in the mix. Sounds like an experiment for some rainy day. :idea:
I suggest it doesn't really matter for 1/2 inch. But, I understand the thought of it causes a lot of angst for the typical Aker.
Oh, my concern wasn't conductive, it was more practical/physics. Each conductor is two conductors twisted together, it would be hard to trim them without thinning going into the twist and potentially making them less resilient/more prone to breaking.
