And in the first comment, I would like to ask for advice about speakers for my TV room( 4,5m x 6m). The speakers stand against the wall 4.5 but the door takes 80cm from the side. I am looking for tower speakers that can be placed close to the wall, a maximum of 10 cm from the wall, and one of the speakers will stand in the corner by the window.
I've read and watched a lot of reviews on youtube, but I'm not sure I can make the right choice, moreover, often only those columns whose marketing spends money on it are considered.
As I understand it, for installation next to a wall, it is better to use speakers with a phase inverter opening down or forward or completely closed type.
While I'm thinking, would it be good to use the polk audio K700 in such conditions? I have also heard that the klipsch A8000 II, despite the exits from the rear, can be placed close to the wall. but I'm not sure that it will work well. maybe you should look at the triangle bro9 (bro 10 will appear soon) or look towards the klh model5 (but it is confusing that after enthusiastic reviews all reviewers somehow dislike it, they also need a subwoofer, which increases the price and the frequency range will not be so smooth). my budget is 1500-2500 per pair. or if there are very good options that are worth it, I'm willing to buy used ones on the same budget.
I'm building a system from scratch so that the amplifier and dac will be selected based on the speakers. for example, for the polk r700, I'm thinking of taking the yamaha 1200 and holo audio Cian 2.
by sound, I like a surround sound with a slight color towards an enlarged body with a forward pitch and with slightly crossed out vocals. the upper frequencies are quite a bit softened but detailed.
This is a very big problem by genre, as the music is very different from EDM to symphony orchestras from rock to reggae.
Recommend which speakers you should pay attention to for such conditions .
I live in Barcelona. Unfortunately, the opportunity to try out speakers at home is not very developed here. For example, the klh model 5 can only be bought without returning to the store and you cannot listen to it because there is no sample in the stores.
