with power off for a while, drop the filter and mixing boards through the bottom, inspect them closely for damaged parts. Out of circuit test the transistors (one at a time, no mixing) and ohm test the resistors with one leg lifted.
odds are good you will find the induced damage that way, but the original issue of signal strength is probably a capacitor.
when I go power on for testing, either the boards are all secured in place and buttoned up, or they are on long wires that have them away from the chassis, or in some way out in the open, probably on carpet fragments, and secured from moving. usually i don't if i can possibly avoid it.
