There are existing lists.
list of lists:
https://audiokarma.org/forums/index.php?threads/pioneer-recap-lists-sticky-suggestion.457663/
spec-1 list:
https://www.audiokarma.org/forums/i...-spec-1-repair-and-restoration-thread.445669/
on the parts lists the are getting the same volt CAP's I thought it was a good idea to go up on the volts when buying new caps?
C7 & C8 OF which BOARD? Some are upw, some are ukl,
Board is AWM-082B ZYA
I can figure out the CAP's, can you just clarify how to tell what ones are polar or bi-polar.
So this list is for my board?
Filter Amp Board (AWM-082) (The "B" revision of this board has a 1000uF 25v CEA cap in front of the reed relay, unknown cap number.)
AWM-082: C1: 3.3uF 25v BP: 647-UES1H3R3MDM 3.3uF 50v
AWM-082: C2: 3.3uF 25v BP: 647-UES1H3R3MDM 3.3uF 50v
AWM-082: C3: 3.3uF 25v BP: 647-UES1H3R3MDM 3.3uF 50v
AWM-082: C4: 3.3uF 25v BP: 647-UES1H3R3MDM 3.3uF 50v
AWM-082: C5: 33uF 25v BP: 647-UES1E330MPM 33uF 25v
AWM-082: C6: 33uF 25v BP: 647-UES1E330MPM 33uF 25v
AWM-082: C7: 2.2uF 50v CEANL: 647-UKL1H2R2KDDANA 2.2uF 50v (Silk screen polarity is wrong!)
AWM-082: C8: 2.2uF 50v CEANL: 647-UKL1H2R2KDDANA 2.2uF 50v (Silk screen polarity is wrong!)
AWM-082: C9: 4.7uF 35v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWM-082: C10: 4.7uF 35v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWM-082: C27: 2.2uF 50v CEANL: 647-UKL1H2R2KDDANA 2.2uF 50v (Silk screen polarity is wrong!)
AWM-082: C28: 2.2uF 50v CEANL: 647-UKL1H2R2KDDANA 2.2uF 50v (Silk screen polarity is wrong!)
AWM-082: C29: 4.7uF 35v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWM-082: C30: 4.7uF 35v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWM-082: C31: 10uF 25v CEANL: 647-UKL1E100KDDANA 10uF 25v
AWM-082: C32: 10uF 25v CEANL: 647-UKL1E100KDDANA 10uF 25v
AWM-082: C33: 3.3uF 25v BP: 647-UES1H3R3MDM 3.3uF 50v
AWM-082: C34: 3.3uF 25v BP: 647-UES1H3R3MDM 3.3uF 50v
AWM-082: C35: 3.3uF 25v BP: 647-UES1H3R3MDM 3.3uF 50v
AWM-082: C36: 3.3uF 25v BP: 647-UES1H3R3MDM 3.3uF 50v
AWM-082: C37: 100uF 6.3v CEA: 667-EEU-FM1E101 100uF 25v
AWM-082: C38: 100uF 6.3v CEA: 667-EEU-FM1E101 100uF 25v
AWM-082: C51: 470uF 6.3v CEA: 667-EEU-FM1A471 470uF 10v
AWM-082: C52: 10uF 16v CEA: 667-EEA-FC1E100 10uF 25v
AWM-082: C53: 10uF 16v CEA: 667-EEA-FC1E100 10uF 25v
