Ok, measure the voltage across R15 (R16 right). one dmm probe on opposite sides of the resistor at the same time.
R15, R14, R13, D1 & Q5 form a constant current source that is fed to the STV diodes for a particular voltage across it at a particular temperature. Drop the current, drop the STV voltage and thus drop the idle current.
voltage divided by resistance is STV-x current. EXAMPLE: 1.35 v / 220 = 0.006136363636 or about 6 mA
if we go to 240 ohms, 1.35v / 240 ohms = 0.005625 5.5 milliamps
if we go to 270 ohms, 1.35v / 270 ohms = 0.005000 5 milliamps
which will drop all the stv-x voltages correspondingly. Which will drop the idle current range adjustable by the VR.
This all depends upon your R15 (R16) voltages and currents. What are they?
The question is, why did this happen - what did you use for Q8, Q9, Q10, Q11 and the outputs?
modern transistors (on-semi it seems) have dropped their Vbe's a few millivolts, and it all adds up rather quickly. They are apparently shifting their purchased Fairchild transistor lines into their proprietary process which is different (better?) than the old Fairchild process.
I tried to avoid the on-semi's that did this in my replacement lists, but that change is becoming too widespread.
edit - r16 brain fart...
