I just bought a Spec 4 that has issues.
The unit has been worked on in the past. Several resistors on the right amp board were replaced with higher wattage versions.
When the unit does power up, after a few moments, the left channel wattage meter jumps violently a few times and then the protection relay kicks out. The right channel pops thru the speaker. All this with nothing connected to the inputs.
I have +73v on pin 1 and -73 v on pin 3 of the AWR 139 power assembly
I have +73v on pin 1 and -73 v on pin 3 of the AWR 140 power assembly
My fuse assembly is AWR 144, not 143 as in the service manual. It is laid out differently and the pin numbers don't coincide. I have + 90v on pin 1 and -90v on pin 18.
I discovered that the wires for pins 21 and 20 on the right channel were reversed and corrected that. I wonder what damage that caused.
Where do I start?
Thanks
Where do I start?
Thanks
