I still have drift with the DC balance. After 2 hours, I did the adjustment procedure in the service manual. Both channels seem to drift between +25mv and - 20mv. Not sure if that's normal or an indication of problems. The receivers I've worked on seem to be more stable.
As mentioned in an earlier post, this unit has been worked on in the past. Kind of a hack job, very sloppy work. On the left channel, all of the outputs were replaced with Toshiba's of a different part number than the originals. Also several resistors were replaced. In one case, the replacement resistor wasn't soldered to the board, probably made contact with the mechanical connection. Replaced the outputs with matching Onsemi's. Replaced all electrolytics and the trimpots, and cleaned-up the sloppy work.
What's recommended for cleaning off the rosin from the PCB?
Based on the Watt meters, it seems the right channel is weaker at a given setting, it does sound OK though. Any way to adjust this?? With the exception of the DC Balance drift mention above, both channels are set the same.
Thanks for the help.
