OK, two things to do, watch the + 68v(pin 2) and -68v(pin 6) power supply voltages over the drift period to see if the power supply is inconstant.
Also I would watch the output offset that is drifting to see if there are correlations between the drifts in the two channels - like the right channel rises 60 millivolts while the left rises how much, and is it repeatable?
I would also tie both R6's to ground instead of the wiper of VR1. That gives us a rock solid offset input (not something dependent upon the stability of the supply voltages), even if the value isn't zero at the output. The voltage readings at the bases of Q1a & Q1b did stay stable, implying the Q1 stage is doing it's job.
If that doesn't turn up anything, then we do the gain of one thing with either a capacitor or bypassing the R22 feedback resistor.
I feel that anything misbehaving after Q1 in the circuit by drifting would also affect the idle currents' reading.
