calavera68
Member
Hello,
I decided to restore my Spec2 after reading some threads about it from users @mattsd and @markthefixer. I replaced all transistors and film capacitors in the power amp boards, power supply board and amp meter board with the exception of the output transistors. I also replaced 2 relays in the power supply board, 1 relay in the meter board and the reed relay RL1 that often goes bad.
I was hoping for help from the pioneer experts in the forum to find where the issue resides. I made some measurements that @markthefixer asked for a member on a similar issue from an old thread as a baseline
Left channel:
vr1 to zero ohms.
pin 22 gr 88.7v
pin 23 gr 1.83mv
pin 14 gr 1.8mv
pin 15 gr -89.9v
across r9 4.7k 2w yellow violet red 53.4v
d2 cathode gr 35.08v
across r4 15k ohm brown green orange 34.4v
across r7 33k ohm orange orange orange 61.7v
across r8 15k ohm brown green orange 27.95v
across r5 1.8k brown gray red 2.12v
across r6 1.8k brown gray red 2.0v
across r11 100 ohm brown black brown -30.8mv
across r12 100 ohm brown black brown -31.8mv
across r13 100 ohm brown black brown -35.5mv
across r14 100 ohm brown black brown -35.2mv
q5 collector gr -26mv
q7 collector gr 1.78mv
Coil to pin 4 to gr 27.6v
Contact to pin 15 to gr -90v
Right Channel:
vr1 to zero ohms.
pin 22 gr 88.6v
pin 23 gr 1.86mv
pin 14 gr 1.83mv
pin 15 gr -89.8v
across r9 4.7k 2w yellow violet red 53.6v
d2 cathode gr 35.13v
across r7 33k ohm orange orange orange 62.2v
across r8 15k ohm brown green orange 27.7v
across r5 1.8k brown gray red -2.12v
across r6 1.8k brown gray red -2.03v
across r11 100 ohm brown black brown -30.6mv
across r12 100 ohm brown black brown -30.8mv
across r13 100 ohm brown black brown -0.025mv
across r14 100 ohm brown black brown -.06mv
q5 collector gr -0.895mv
q7 collector gr 1.8mv
Reed relay
Coil to pin 4 to gr 28.7v
Contact to pin 15 to gr -86.2v
Any help I receive will be greatly appreciated.
Regards,
Pedro
Left channel:
vr1 to zero ohms.
pin 22 gr 88.7v
pin 23 gr 1.83mv
pin 14 gr 1.8mv
pin 15 gr -89.9v
Right Channel:
vr1 to zero ohms.
pin 22 gr 88.6v
pin 23 gr 1.86mv
pin 14 gr 1.83mv
pin 15 gr -89.8v
Reed relay
Regards,
Pedro
