SS Amp Storage ???
bokat57
Hi
How should a solid state amp be stored ?
How long can a solid state amp be stored before the parts degrade ?
Thanks :thmbsp:
Bob
Bonus question why are ss amps called " sand "
As long as you want. Stored in their original cartons, plastic bags and silica gel packs, they can be happy for decades. I have gear that hasn't been out of its box for 20-30 years. I recently powered up an amplifier I hadn't turned on in 30 years.
I use a ATA flight case, you can add foam to fit any size amp securely. My M-504 is a perfect fit, the WOPL needs additional
Pretty well anywhere dry and indoors.
Note that the PS Electro caps Will deteriorate with time, in use or not.
In the very least they will need reforming to revive.
sand is silica (silicon dioxide) which is key ingredient for the manufacturing of semiconductors ( solid state ). It is also a key ingredient for glass ( valves & tube envelopes) :scratch2: A lot more "sand" in tube amplifiers actually.
