If you're really trying to keep it stock but with a new board, honestly I'd go for a 6GH8/6U8 driver instead. its a very similar tube but good ones can be had. 7199 stock is pretty limited and the ones you can get may not be much good.
Elsewise honestly I'd just rebuild the stock board if you're really set on keeping a 7199 in there.
I am a bit torn on this angle. I fully understand the equation of old tube 7199 becoming harder and harder to find. However it is far from unobtainium as some suggest, more that it commands a premium due to availability. The actual struggle I am really having is whether to replace the board at all? My soldering skills and equipment are of a novice level, and I am dubious of reworking the original board myself for fear of the traces lifting or otherwise mucking it up as I have read repeatedly. Seems replacing board (oem design) with a more recent production/materials/pre-populated is the easiest approach, but does veer a bit away from oem? I would love to find some like minded AKer local to me who has the skills needed to rework the original board, and as Ferninando said
IMO the driver board does not NEED replacement. It is not scorched.
A good cleaning and new parts will make it like new.. All the Rs and Cs are available.
Then just give it 6-12 mos of listening and then decide if it is really necessary to
get a new board. I think you will decide no.
So again, if anyone local to me (Southern NH) is of a mind to give me some assistance with this, I believe I would like to keep the oem board and rework with fresh components. I would be happy to drive to or host an afternoon of board rework.
As promised, a few more pics of the disassembled guts of this thing, first the transformers.
and again, all I have done is extract from chassis (desolder not cut wires) and of course I tagged and recorded all leads. A bit of mild cleaning and a coat of wax leaves these in very presentable condition and I am not even considering repaint. I much rather the romance (and appearance) of original, a little beat up as opposed to a perfect appearing repainted anything.
The choke shows no evidence of overheating and I have done virtually no cleaning prior to taking this picture.
and I have seen a 65 on this and all transformers as well. Safe bet it was produced in '65 yes?
Then this pile of pieces/parts is all in decent shape, depending on final decision of board approach will dictate just how much of this gets undone. I will get new (oem style) switches for power and m/s. The fuse holder is not oem I am told so will effort an oem style (or original) if available. I have not taken close ups but a question about the tube sockets. On one side it appears as there is some crusty remnants on the top surface of the sockets. Not a lot, but definitely there. The other side pair is clean to the original surface and no evidence of crustiness. In the below pic the bottom pair of sockets is the clean pair and the upper shows the crustiness. I will get some better pics of this later but thought I would mention now.
Then there is the cap can. Again I did not take close up but there is definite evidence of crusty leakage coming out of the bottom of this thing. Forget the romance, just replace with a new version unless someone has other ideas?
My real quandary is about the cord. I suspect I can clean this original one and reuse, but I am leaning towards replacing (and grounding) cord with something a bit more substantial. Where do I draw the line for keeping it original?
Folks, I greatly appreciate the input here.
Geoff
